Go back and edit button styles
Thread began 8/05/2011 10:16 am by email405213 | Last modified 8/05/2011 12:00 pm by email405213 | 1351 views | 2 replies |
MarkBeta Tester
Is there way of once the button has been created, you can go back and edit the style of the button.
Is there a feature in button styler to do this, or, is it a case of once the button is created, you then have to fiddle-arround with css coding etc.
thanks
Mark
select the button in design view, then go to Webassist -> CSS Button Styler -> Insert CSS Button.
MarkBeta Tester
Yes, that worked, thanks.
Seems a little strange to go to the insert button again to edit the button - but as long as it works - its great.
Maybe in next release just have a menu which says 'Edit button' which wont confuse thicko's like me! (even though the action is the same)
CHeers
Mark
