Can i send out 2 different emails at once?
Thread began 8/04/2011 3:59 am by jegoadby285710 | Last modified 8/04/2011 7:35 am by Jason Byrnes | 916 views | 1 replies |
jegoadby285710
Hi
Is it possible to send out 2 differently formatted emails form a web form i.e.
One that goes to the company with all personal information about a booking
And
One that goes to the customer but with limited information
If its possible to do this id be happy if you can tell me how.
Kind regards
John
yes, it is possible to do this, you would need to add 2 instances of universal email, make sure the first one does not have the Go To page set, only set the redirect in the second.
if you elect to use one of the templates, you will need to edit the code on the template to tell it which form elements to leave out.
at the top of the tempalte page, will be the folowing code:
$remove
= array();
$remove[]  = "";
$remove[]  = "x";
$remove[]  = "y";
$removeBegins = array();
$removeBegins[] = "Security";
$removeEnds = array();
$removeEnds[] = "_x";
$removeEnds[] = "_y";
$removeIncludes = array();
$removeIncludes[] = "Security";
add the form element names to the remove array that you do not want to include in the email to have them removed:
$remove = array();
$remove[]  = "";
$remove[]  = "x";
$remove[]  = "y";
$remove[]  = "elementOne";
$remove[]  = "elementTwo";
