Enum ignored, and no delete option on results page
Thread began 8/02/2011 12:25 am by david428573 | Last modified 8/02/2011 7:15 am by Jason Byrnes | 941 views | 1 replies |
david428573
Using DW CS5 and DA 2.0.8, two serious bugs:
1 - I have a database field defined as an 'enum' - there appears to be no way to coax DA into using the valid values of this field as choices either in a radio group or a <SELECT> field.
2 - The tutorial refers to the option to add a "Delete" button to the results page, but that option does not appear anywhere that I can see it
I would like to accept the offer of a 15-day unconditional refund unless these bugs have fixes. No hard feelings, I just need these functions to work, and I can write the code myself, just thought it was worth $100 to have the wizard do it for me.
1) No the wizard cannot create the select lists or radio buttons for you, but you can add the values to the select list or radio buttons after the page is created.
2) when you run the wizard, if you select the option to create a delete page and set the Results page type to administrative, the delete button will be added to the results page automatically.
if you still wish to pursue a refund, contact the sales department by email at sales@webassist.com
