product options color and size options
Does this work without a database?
yes, you can do options without a database.
in the cart object, set up a column for color and size.
Set each of these new columns to be unique.
In the add to cart button behavior, set these color and size options to updateable from a select list.
after the add to cart button behavior creates the select list, you can populate the lists with the appropriate values.
got it can I rerun ecart display manager and ecart check out I hope
no, the display manger and checkout wizard are not re-entrant, you would need to delete the existing display manager then reapply it.
for the checkout wizard, you asked this in another thread, see my reply there.
when I do a submit order I get
Unknown column 'LST650' in 'field list'
I am doing this with no gateway just local do I get a email or where should it be going for completeing the order just using static values?
How do you get the order information I missed something I am passing the static information all the way to the cart. When I complete order I get an a table in orders listing that had the billing info but where is the order info.
the order info will be stored in the order details table.
