One last error
Thread began 7/29/2011 5:15 pm by genelee2330761 | Last modified 8/01/2011 8:22 am by Jason Byrnes | 787 views | 1 replies |
genelee2330761
One last error
I just transferred all the files from my site from the test server to the permanent host. I built the database and used the SQL export to create an SQL query to build the tables and populate the current data into the new host then changed the database references in the files in the connections folder to point at the new database/host. But, when I try to login now I get the following error:
Warning: mysql_select_db(): supplied argument is not a valid MySQL-Link resource in /home/content/21/8121221/html/webassist/security_assist/helper_php.php on line 30
Warning: mysql_query(): supplied argument is not a valid MySQL-Link resource in /home/content/21/8121221/html/webassist/security_assist/helper_php.php on line 35
I get the feeling that I missed something in setting up the new database but can't see where it might be.
