Bug - Broken Behaviors
Thread began 7/28/2011 1:23 pm by neo314 | Last modified 7/29/2011 9:18 pm by neo314 | 1201 views | 2 replies |
neo314
Can I assume you are aware of the broken behaviors issue? I have a plugin whith a record set and repeat regions. The repeat regions show in the Server Behavior window, but they show as broken because the recordset does not exist as far as DW is concerned. The page works, but the broken behavior display is annoying.
I am using DW3.
yes, this is an issue we are aware of and should be corrected in the next update.
neo314
Thanks Jason. I also noticed page relative links are not translated in case that one is not known.
