Downloading a 34Mb ZIP file fails
Thread began 7/27/2011 11:05 am by bbifl346249 | Last modified 7/27/2011 12:50 pm by bbifl346249 | 1051 views | 5 replies |
bbifl346249
RMPsD_dl.php
The Firefox download tab says, "starting.." for approx. 5 minutes before failing with the message, "C:\Users\SAS\Downloads\RIPMaster_Ps_Free.zip.part could not be saved, because the source file could not be read.
Try again later, or contact the server administrator."
Any ideas anyone ?
You could try extending the server timeout on top of the page:
set_time_limit(0);
a '0' time limit is actually unlimited. One possible issue with this is that some servers won't let you change the time limit for scripts. When that is the case it could be difficult to solve without changing hosting providers.
bbifl346249
Not a PHP time out error ?
OK, I've tried it with LOTS of different file formats and sizes.
A file of approx. 30MB downloads in approx. 1minute 10 seconds.
ANYTHING OVER 32MB FAILS ! ...... do you think this could be a script problem ? I do :D
WebAssist ?
It seems unlikely that it would be a script problem. Most likely it is a script timeout or you may need to increase your memory_limit setting in your php.ini.
I can set up a test here to see if I can reproduce the problem and identify a script issue.
bbifl346249
Test ? Yes Please
This post has been deleted.
bbifl346249
memory_limit ?
I see that the memory_limit is set to 32M :D I'll see if I can change this ?
bbifl346249
Sorted, thank you !
Created a php5.ini file and set to 64M and everything works.
THANKS ..... I love WebAssist (Not in a homosexual sort of way) ;)
