Display Manager Parse error
Thread began 7/27/2011 6:18 am by vmartinez310076 | Last modified 7/27/2011 7:21 am by vmartinez310076 | 926 views | 2 replies |
vmartinez310076
I'm using eCart 5.0.3
When adding items to the cart, I keep getting the following errors:
Parse error: parse error in C:\wamp\www\PhoenixCruiser\WA_eCart\WA_eCart_Definition_PHP.php(477) : eval()'d code on line 1
Notice: Undefined variable: nextItem in C:\wamp\www\PhoenixCruiser\WA_eCart\WA_eCart_Definition_PHP.php on line 478
I have attached a zip file with containing the files.
An help will be greatly appreciated.
Thanks,
Vince
WA_eCart_Definition_PHP.zip
I don't think this is an issue with the pages you have attached. Maybe an issue with the item added itself, or maybe something to do with having magicQuotesGPC enabled and having a quote in the product name?
One way to debug is to comment out lines 477 and 478 where the errors occur and add this line in its place:
echo("\$nextItem =".$toExec.");");
Then add this a few lines later before the "return $retArray;" line:
die();
Then when you go to the page that was giving the error it would write the code to the page that was causing the error. If I looked at that I'd be able to be more confident in my diagnosis.
Without seeing that my best guess is that you have magicquotesgpc enabled and have a quotation mark in your product name.
vmartinez310076
Fixed
Thank you. I did have magicquotesgpc enabled.
Vince
