Buy specific item get 1 lesser value free
Thread began 7/26/2011 4:44 am by sandy259886 | Last modified 7/26/2011 9:42 am by sandy259886 | 4673 views | 2 replies |
sandy259886
I want to do a promo where if you buy item number "X", you get a free item of equal or lesser value free. I have excluded products, so I've added a field to the database that puts a "discountable price" in the cart and all promos work on that figure rather than the subtotal of the cart.
I'm not quite sure where to start. I know my rule will begin with the item present, then, what?
It would take custom coding to pull this off. It isn't going to be covered by a rule.
You'd have to add php code to loop through the cart, find the most expensive item less than the promo item and then create a session variable to store the amount.
The rule would just discount the amount stored in the session variable... but you'd need custom code to determine how much. It is only a handful of lines of php code, but you'd need to be able to write php to loop through an array and set the session variable by hand.
sandy259886
I'll give it a go
Thanks! I think I might be able to manage that. If not ... may be back for a custom quote.
