Supersite
Thread began 7/24/2011 12:38 pm by john70964 | Last modified 7/26/2011 6:10 am by john70964 | 1201 views | 2 replies |
john70964
Supersite
Hello
When I downloaded Supersite recently I noted I had:
Folders for SecurityAssist with extension Security Assist 201.mpx
and SecurityAssist 1.x with extension SecurityAssist119.mxp
Also I have Data Assist with extension WADataAssist131.mxp
and Data Assist 2 with extension WADataAssist208.mxp
Can anyone say which folders should be used
Many Thanks
John
You should be installing Security Assist 201.mpx and WADataAssist208.mxp.
Those are the most recent versions. The others are left in your order history for legacy support and shouldn't be used if you don't already have sites built with them that you don't want to update.
john70964
Thank you Ray
lsmcs432616
Super Suite Serial#
When I purchased Super Suite all the extension below were suppose to be included however I cannot use CSS Sculptor because none of the serial#'s are correct. I was following the instruction for Getting Started with Super Suite, so I need help knowing what I can use and what I cannot use. Also I don't see SiteAssist Professional anywhere. I am bit lost. Where should I start. The sited I had a 1/2 hour of free tech support, but not hours are not compatible with mine. Please help
CSS Sculptor (CS3 or CS4)
CSS Menu Writer
Surveyor
DataAssist
Digital File Pro
SecurityAssist
Cookies Toolkit
Validation Toolkit
Dynamic Dropdowns
Universal Email
eCart
iRite
Dynamic Web Charts
Pro Maps for Google
Web Standards Advisor
Site Import
SiteScribe
Looking in your Order History, the version of Super Suite that you purchased is the most recent version that is comprised of;
eCart
Design Extender
Data Bridge.
Design extender is consolidation of the following extensions:
-- CSS Sculptor
-- CSS Menu Writer
-- Framework Builder
-- PowerCMS Builder
-- Pro Maps for Google
-- Site Import
-- Site Sculptor
-- Social Media Toolkit
Data Bridge is a consolidation of these ones
--CSS Button Styler
--CSS Form Builder
--DataAssist
--Digital File Pro
--Dynamic Connections
--Dynamic Dropdowns
--Dynamic Web Charts
--Form Toolkit
--HTML Editor
--Image Resizer
--SecurityAssist
--Universal Email
--Validation Tooltips for Spry
When trying to use CSS Sculptor, you would be activating Design Extender, so should use the design Extender serial number.
lsmcs432616
Super Suite Serial#
Okay, I had to try several time before it worked, but it finally worked. I would say there was a typo, but I copied and pasted from my account, so not sure what went wrong the first few tries.
