some sessions disappear when..
Thread began 7/23/2011 10:39 am by wbrooks199805 | Last modified 7/26/2011 8:47 pm by wbrooks199805 | 1262 views | 7 replies |
wbrooks199805
security code is entered wrong and has to be done again! A bunch of invisible fields don't show up in the database.
Any idea of why it would do that? It works great prior to that.
I thought maybe I needed put the hidden fields above the security, but that didn't work.
Heres the link. uploads.php
Can you attach a copy of that page so I can see what might be wrong? I'm not sure that I understand your description of the problem either.
Are you saying it works fine if the security code is entered correctly the first time, but if you enter the wrong security code then some fields are cleared?
wbrooks199805
Yes
That's what I mean. I am attaching the file. I am binding sessions to the database. Is that wrong? I have been thinking about that. Should I bind the field names?
uploads.php.zip
The ones that are clearing out are the ones that you have bound directly to the posted form from the previous page like:
<input name="usef" type="hidden" id="usef" value="<?php echo((isset($_POST["usef"]))?$_POST["usef"]:"") ?>" />
Instead you should be posting the previous page to itself and storing those as session variables. Then redirecting to this page and populating the hidden form elements from the session like you do the other fields.
wbrooks199805
Okay..will try it
On another note and very important. Are you still able to support Network solutions with ecart? Because they set up client up with USA epay.
eCart doesn not include USA epay support. However the shopping cart will still work, so you could integrate USA epay by following their documentation and samples and using their support. There is no reason why it wouldn't work, we just haven't added it for you.
wbrooks199805
thanks
Yeah, that's too much work! Thats why I have ecart.
I am getting them to switch to authorize.net's gateway..I just found out they still have it. The were trying to bamboozle my Client saying they didn't Authorized.net didn't have a gateway!
wbrooks199805
that was it!
I must have been sleeping..I did it on a bunch of form pages..thank you!!!
