Content Disappears on Page
Hard to describe this. If I add a Google Map to a page created by the Dreamweaver Master-Detail page set the Google Map displays but all of the content of the page disappears. If I remove the map the content comes back.
Can you put up a sample page where I can reproduce the problem? This shouldn't be happening, but if I can see it I might be able to determine why it is.
I re run the wizard and the content is now back. But the Google Map just shows the default location (in the USA) and not the loation related to the record returned from the DB.
Please post a url to view the page in a browser. I can't easily set up a testing environment to look at your pages you have sent.
Problem is that it's being developed on my testing server.
However, I'll set up a testing site online. May take a while.
I've created a test site online at accomodation_and_venues.php. Click on the more info link to get the detail.
It is now doing the same thing that I first mentioned - content has gone and map is showing USA, not my location.
I notice that when I put in the postal address it seems to wipe the content. In the DB this field is called Address. If I add Town and postocde it seems to at least show the map, although the location will not be accurate.
It appears that the geocache page isn't functioning properly, and since you are trying to plot so many data points it surpassing the maximum limit allowed by google. The cache system is meant to get around that problem. I'll open a support incident so that an engineer can look into this with you directly.
Ok, sorted it! The problem was that I had spelt Northern Ireland wrong (I had Nortthern). Doh!!!!!
