Browse Server in HTML Editor is not showing images
Thread began 7/21/2011 11:04 am by nibo | Last modified 7/25/2011 7:42 am by Ray Borduin | 1704 views | 3 replies |
nibo
I have had this workingbefore, however for some reason now it's not.
When I want to insert an image into a HTML Editor instance I click on the Image icon which brings up the Image Properties pop-up. I then click on Browse Server. The File Manager pop-up page displays as it should, with the exception that there are no thumbnails displayed.
I have enabled Show Directories so I get a grey panel on the left, however there are no directories listed and no thumbnails in the main area to the right.
If I use the Browse button at the top, select an image and then click Upload, then the thumbnails all appear. Still no directory listing on the left.
I have had to re-install HTML Editor after the Webassist>Forms>Insert File Manager windows was unresponsive, however I've checked all the various settings and everything seems correct.
I would very much appreciate help to get it working again.
Windows 7 64Bit
Dreamweaver CS5
HTML Editor (3.0.2)
GD2 enabled in php.ini
EDIT:
It must be to do with the paths and folders. I tried another page, which did not have a Sub-folder specified in the HTML Editor instance settings and the thumbnails do appear.
I thought that any sub-folders that you set there will be "under" the folder that's set in the WebAssists>Forms>HTML Editor>Site Settings box?
We'll have to debug this issue with you directly in order to try to find the cause. I've opened up a support incident for you. Please update the incident with a phone number and good time to reach you and we can help you with this directly.
info404064
Same problem
Hello,
I have the same problem, the same configuration is Windows 7 64Bit, Dreamweaver CS5, HTML editor (3.0.2)
I've tried everything but problem remains.
Regards, DM
I've opened a support ticket for you as well.
