Adjust mailto
Thread began 7/21/2011 12:09 pm by SPT | Last modified 7/21/2011 12:54 pm by SPT | 684 views | 2 replies |
SPT
Adjust mailto
I recently had to go in and change the email address the form is sent to.
I did notice when I go to "Form Function" it did not retain the the email address I had earlier had it set to. I added the updated email address and now it sends to both addresses.
Which file controls the mailto function so I can go in and manually set it and remove the old address?
The Form Builder works much better as a "Builder" and an "Editor"... once your form is created you should be using the server behaviors to make edits rather than trying to rebuild the form.
In this case don't go to the form builder wizard at all, just double click on the Universal Email server behavior applied and change the email settings from that interface.
SPT
Awesome, Thanks Ray - I should know better....:)
