Input changes in database and post
When any info is posted to page or database, if there is something in quotes or using ' or " it adds a / backslash. I am using a text field. How do I get rid of that?
it sounds like your host has the magic_quotes_gpc setting in the php.ini enabled, this is a deprecated function and should be disabled in the php.ini file, contact the hot to have them disable the magic_quotes_gpc setting.
I am using my remote host..I am on a really old mysql and php but uploaded the php5.ini file and didn't work.
I guess it will be ok on the host. BTW, using 1and1.
I've not had any problems getting 1 and 1 to recognize the php5.ini file, you should contact 1 and 1 support if you are having difficulties with this.
I haven't tried it on their server yet. I am sure it will be okay. thx
