Buffer Problem when used with Framework Builder
Thread began 7/20/2011 9:02 am by codamedia | Last modified 7/20/2011 1:06 pm by Jason Byrnes | 761 views | 1 replies |
codamedia
I am trying to include a map using Framework Builder. It works OK (with a little tweaking) if there arn't too many locations, but if there are more than 20 or 30 locations the map does not display (it doesn't hang long either, but it simply does not display).
I believe this is related to the buffer (ob_start) Framework Builder uses. Is there any way to increase the size so I can load much larger maps (ie: 500+ locations).
