Set a Default Location
Thread began 7/20/2011 11:58 am by codamedia | Last modified 7/20/2011 4:06 pm by Jason Byrnes | 692 views | 1 replies |
codamedia
I am collecting addresses from a Record Set, and I believe the default behaviour of this configuration is to center the map on the last record found.
This does not work well for my situation, and produces unpredictable results (sometimes even defaulting to North America if it cannot find a location).
I tried to add a second entry (one that uses the record set, then a static entry) and although I set the static entry as the default, it doesn't seem to work.
Any suggestions?
