Set session on submit
In the attached file I have tried to set a session variable using the submit button. I want to viewer to enter a promo code once during the session. Why does this fail?
I assume it the placement of the set.
Nick
Nick
the promo code form is set to use the GET method,
change the following code:
if(isset($_POST["buttonPromo"])) {
$_SESSION["promoID"] = "".((isset($_GET["promoID"]))?$_GET["promoID"]:"") ."";
if(isset($_GET["buttonPromo"])) {
