'kfm_resizeHandler'
Hi when I login to the server i get the attached error message, basically could not find function 'kfm_resizeHandler' on the server-side!
Also still need an answer too: showthread.php?t=21732
regards Alistair
regards Alistair
there is no attachment, what is the exact error?
we need the exact error to look into the cause.
I started a ticket to look into the other issue.
I will look into this issue with you when i look into the other issue i started a ticket for.
