Problem with delete multiple records
Hi, applying the behaviour, the page give me a pop up error (javascript error).
The page, infact, doesnt' work.
Can you help me?
I attach the test page
Can you help me?
what is the error you get?
Delete the Dreamweaver Cache file from the users configuration folder:
When I press OK in the wizard (after having inserted all the parameters) there is an error pop up (I attach the screen view). After this, the behaviour is present in the code but the deleting behaviour doesn't work.
