PowerCMS Builder 1.01 Issues
Thread began 7/16/2011 3:53 pm by Lee Firth | Last modified 8/13/2011 10:06 pm by InnovaDave | 1312 views | 4 replies |
Lee Firth
I have just upgraded to the latest version. I was half way through converting an existing website to PowerCMS but now when I try to add content to PowerCMS when the dialogue box opens (see powerCMS1.jpg attached) under "Content Locations", "Existing" is greyed out, I know it's there as it is in the Admin area (see powerCMS3.jpg).
I then tried to add it by adding the content are using the Admin area first and then trying to add the content using "Insert Content from PowerCMS". The drop down lists for Content Location and Content Area are empty (see powerCMS2.jpg attached).
Go to the Database tab, double click the PowerCMSConnection and click the test button, does the power cms connection test OK?
Lee Firth
I don't think there is anything wrong with the database connection file, it connects fine and as I said in the initial post, I can use the Admin area to add and edit content areas so it must be something else.
InnovaDave
Same Issue Here
I'm having the same problem. The DB connection works fine but the Content Location and Content Area are greyed out. I can't type anything and there's nothing in the dropdowns. Please advise...
Dave C
