Product Option labels
Thread began 7/16/2011 12:24 am by anitah355532 | Last modified 7/20/2011 1:03 pm by Jason Byrnes | 2188 views | 7 replies |
anitah355532
Can you please tell me how I can get the product options text labels to show properly? I've tried everything i can think of ...
The text describing the option "Ribbon Colour" is being cut off and is showing as "Ribbon Colou... :
The site is at www.ambiencebymichelle.co.nz.
I've attached a screen print so you can see what I mean.
Thanks, Anita
on the webassist/plugins/shopping_cart/add_to_cart.php page, change the following code:
<?php echo substr($row_SubOptions['OptionGroupName'], 012); ?><?php if(strlen($row_SubOptions['OptionGroupName']) > 12) echo "... "?>
<?php echo $row_SubOptions['OptionGroupName']; ?>
and this code:
<?php echo substr($row_AddedOptions['OptionGroupName'], 012); ?><?php if(strlen($row_AddedOptions['OptionGroupName']) > 12) echo "... "?>
<?php echo $row_AddedOptions['OptionGroupName']; ?>
anitah355532
Product Options Labels
Thanks Jason .... that's fixed part of the problem.
The initial cart looks just as it should - but when the customer selects an option (small/medium/large) the boxes below jump together, and I'm back to the problem of the labels being cut off.
Images of "before and after" are attached.
in the webassist/plugins/catalogue/change_options.js file, change line 130:
[code]
subOptionInner += '<label title="'+subOptions[x][0]+'" for="SimpleOptions_'+subOptions[x][2]+'">\n'+subOptions[x][0].substring(0,12)+((subOptions[x][0].length>12)?'... ':'')+':</label></td><td>';
[code]
subOptionInner += '<label title="'+subOptions[x][0]+'" for="SimpleOptions_'+subOptions[x][2]+'">\n'+subOptions[x][0]+':</label></td><td>';
anitah355532
Thanks Jason .... that fixed the problem of the cut-off text.
But, are you also able to figure out for me why the boxes are jumping together whenever a customer selects the first option?
Well, I thought the change suggested in the previous reply would fix both issues...
for the jumping together problem try editng the following line from the webassist/plugins/catalogue/change_options.js file:
document.getElementById("subOptionLayer").innerHTML = subOptionInner;
document.getElementById("subOptionLayer").innerHTML = '<div class="addToCartSelect">'+subOptionInner+'</div>';
anitah355532
Perfect .... everything's fixed now.
Thanks for your assistance :-)
you're welcome.
