File Upload Problem. Has Worked Before. What am I Missing?
Thread began 7/15/2011 11:49 am by Justin@AdventDesign | Last modified 7/15/2011 12:57 pm by Jason Byrnes | 1548 views | 5 replies |
Justin@AdventDesign
There has to be something simple here I'm missing. Attempting to add a file upload field like I have numorous times before. Have followed the "Adding Digital File Pro to DataAssist Insert and Update Pages" to a 'T' several times on this one, and still the file doesn't show up, nor does the DB fill the field properly. I'm uploading to the same directory as I am with another form, which still works properly. The entire insert form works fine prior to the upload manipulation, and seems to work fine after, but no file and no file inserted in the DB either.
The only thing different on this than the other insert on this site is the other one I was converting sizes and this one I'm not, since I want to be able to upload PDFs, DOCs, etc. and not images.
The only other thing I can come up with is the table field name is 'file' which ironically is also the input type. Could that be causing some kind of weird conflict?
If not, is there a list of steps to troubleshoot common issues here? I just can't figure out why it works fine on one insert page, and not this one.
please send a copy of your page in a zip archive.
Justin@AdventDesign
Sample file attached
Sample file of the page is attached
tbFaqs_Insert.php.zip
to upload a file, the form encoding type must be set to multipart/form-data.
change:
<form action="tbFaqs_Insert.php" method="post" name="WADAInsertForm" id="WADAInsertForm">
<form action="tbFaqs_Insert.php" method="post" enctype="multipart/form-data" name="WADAInsertForm" id="WADAInsertForm">
Justin@AdventDesign
We Have a Winner!
Thanks Jason. That was the problem. I don't recall ever noticing that before. As you can see, I strip out the data assist formatting for my own, but not sure how that got eliminated at some point.
Works great now, thanks for your help!
By the way, while we're at it, how do I make a feature request for the next update of data assist? It would be really nice to have a non-formatted option that would just generate the code only for each of the pages, without any table and css formatting, for those of us who want to highly customize the layout. It would be a real time saver not to have to manually strip everything out for each iteration.
Thanks again.
you're welcome.
you can make a feature request by submitting to the wishlist forum
