Form Properties Action Box
Thread began 7/14/2011 11:28 am by laura_ellis427550 | Last modified 7/18/2011 2:39 pm by Jason Byrnes | 1323 views | 7 replies |
laura_ellis427550
I have a question that I'm sure I should know the answer to but ...
I've set up a simple contact form (contact.php) and have set the form properties method to Post. What file to I link to in the form properties Action box?
Many thanks,
Laura
you can leave the forms action blank to have it post to itself, then apply universal email to the page, and set universal email to redirect to a thank you page after sending the email.
laura_ellis427550
Email not sending
Ok, thanks - that's not the problem then! I'm not receiving an email when I complete a contact form. I've been through this forum looking at the solutions for others who've had the same issue but with no success.
I've re-done the form so it's at it's most basic. I tried sending it to different email addresses and testing it on both local and remote servers and whilst the thank you page returns correctly I still haven't received an email. I've attached the form to this message and was hoping you could help.
Thanks,
Laura
contact.php.zip
if the email is not sending, the problem is in the SMTP settings of the Universal Email behavior.
what are you entering for the smtp server address and port?
you should double check with your host for the correct SMTP Server address and port number to use when sending an email using PHP mail()
laura_ellis427550
This is the first time I've used Universal Mail and I've also still got a lot to learn when it comes to php!
I had left that section blank because the last few times I've tried to test my form I've been using my local testing environment, rather than the remote host. Do I still need to add SMTP settings in that case?
in most cases, you wont be able to test the email on your local system, you would need to install and configure an SMTP server on your local system to be able to do so.
you should be testing the email on your remote server, using their SMTP server.
laura_ellis427550
I see - I'll speak to Hostpapa and get their settings.
Thanks for the prompt responses - much appreciated.
you're welcome.
