Extension errors all of a sudden
I am getting extension errors from WebAssist extension when I start Dreamweaver CS4 and I'm not sure of what to do about it, please see below;
While executing onShow in WA_Memento.htm, the following javascript error(s) occured:
In file "WA_Memento":
_MementoNotifications.refreshTree is not a function
When I click OK and the Memento panel shows up I get a series of Dreamweaver errors, see below:
wnBGDiv:undefined
scrCenterDiv: undefined
At line 571 of file "C:\Program Files (x86)\Adobe\Adobe DreamweaverCS4\Configuration\Shared\WebAssist\Memento\Memento_shared.js":
document.getElementById("reminderTree") has no properties
I am unable to use WA extensions it seems unless these errors are fixed. I have already removed the extensions through the extension manager and re-installed them and get the same errors.
Is there a way to fix the issue?
