Format DataAssist Date Statment
Thread began 7/12/2011 2:25 pm by Mike Perry | Last modified 7/12/2011 6:59 pm by Jason Byrnes | 1368 views | 3 replies |
Mike Perry
Scratching my head on this one.
DA creates the following code :
<td class="WADAResultsTableCell"><?php echo($row_WADAarticles['date']); ?></td>
where date is an epoch timestamp in a MySQL database. The date currently displays on the Web Page as "2011-07-11 15:35:34" -- I want to display the date as "July 7, 2011".
I can't find the proper placement for the formatting code -- if I do this
<td class="WADAResultsTableCell"><?php echo($row_WADAarticles['date'])('F j, Y'); ?>
(which I believe is the proper formatting code) the line is flagged as an error.
Help??
you need to use both the strtotime() and date() functions
the strtotime() function converts the string to a unix timestamp
the date() function formats the timestamp based on the format parameters you pass in
<td class="WADAResultsTableCell"><?php echo(date("F j, Y"strtotime($row_WADAarticles['date']))); ?></td>
in your code, you where passing the parameters, but not using the data() function
Mike Perry
Thanks Jason -- makes sense now. . .
Have a great evening!!
you're welcome.
