Using Check Boxes in Forms
Thread began 7/11/2011 5:09 pm by Mike Perry | Last modified 7/12/2011 11:12 am by Mike Perry | 888 views | 2 replies |
Mike Perry
I'm hardly a PHP guru, and need to use a check box to indicate whether an online article is active for display or not.
I have a check box for active in the Search, Update, and Insert pages. The articles database has a column called 'active'. The datatype is tinyint, NOT NULL, default = 0 (false).
What code do I alter to have the check box display as checked in the Update page when the article is already active and called to Update, what code is needed to insert a 0 in the Insert or Update pages when the article is not active, and use an unchecked value of 0 for searching for inactive articles and a checked value of 1 searching for active articles.
Error message for Insert and Update is "Column 'active' cannot be null. This occurs when the Active checkbox is left unchecked.
Thanks. . .
Mike
ETA: Search actually works okay -- finds active articles when checked and inactive when unchecked. . .
send a copy of the insert and update pages please.
Mike Perry
I actually just found the solution.
In the php page code I found the following excerpt from the $WA_fieldValuesStr statement:
((isset($_POST["active"]))?$_POST["active"]:"")
and changed it to this:
((isset($_POST["active"]))?$_POST["active"]:"0")
I presume I should probably delete the quotes around the 0, as it should be a number, not text; but it does work. . .
