UE producing 500 error after upgrade to IIS7?
Thread began 7/11/2011 7:33 pm by Nathon Jones Web Design | Last modified 7/12/2011 12:23 pm by Jason Byrnes | 1088 views | 3 replies |
We're using a shared hosting platform and we upgraded a website, previously on Windows 2003 server running IIS6, to Windows 2008 server running IIS7.
UE is no longer working and is producing a 500 error.
Is this a problem with UE or the hosting?
Thank you.
N.
error message
Managed to have the custom error messages removed from the server and here's the error we're receiving now:
Server object error 'ASP 0177 : 800401f3'
Server.CreateObject Failed
/WA_Universal_Email/CDONTS_NewMail_VB.asp, line 92
800401f3
Seems to be a problem with the CDONTS_NewMail_VB.asp file.
How can I resolve this issue?
Thank you.
N.
Cdonts
Ok, so we've tracked down the problem to be that our host doesn't run CDONTS on the 2008 server.
They've asked us to select JMail instead, but they are suggesting that we don't need the username or password in the settings?
Anyway, the UE wizard requested those details so I assumed we were going to run into problems but it seems to be working without specifying a username or password. Does this matter, particularly?
Hopefully this thread will be of some use to someone! :o)
Nath.
Yes, CDONTS is not used anymore by most servers.
in the JMail object, the username and password are optional, they only need to be used if the SMTP server requires them.
