Recordset Relation Manangement
Thread began 7/09/2011 4:12 am by Cologne | Last modified 7/11/2011 5:39 pm by Jason Byrnes | 1335 views | 5 replies |
Cologne
how do I create the manage relation serverbehavior, if I onle got one recordsset?
I got a recordset for t-shirt size (S,L,M etc.)
From this record i create a checkboxlist.
now I want to store the t-shirt data, like name, price, etc in a new databasetable. and store the possible sizes in the relationshiptable.
so I got:
tShirt:
shirtID
shirtName
shirtPrice
size:
sizeID
sizeType
relationTshirtSize:
ID
shirtID
sizeID
The problem is, it is missing the tShirtID cause, the record isnt stored already.
should I use a session?
Cheers
Denis
Lon WintersBeta Tester
I think you're going about it in reverse order. Start with the main tanker table,that contains a unique ID, name price and any other static info for each item. Then create the table for the sizes, also with a unique ID, and another table for colors, again with a unique ID.
At this point they are separate entities and aren't related until a use configures a particular T shirt.
On the selection page, list the available t shirts along with the selectors for size and color. I would use drop downs and populate from the database tables. The drop downs would display the size and color, but the value would contain the record ID. When submitted, insert into an ORDERS table that contains just the IDs for t shirt, size and color. The orders table will have it's own ID to serve as the order number.
If you also capturing user info, include the user ID. The relationship comes not play by the orders table and you can construct a query to display the data.
Cologne
Hey Lon,
its more for my backend :-)
I ad a new tShirt and want some checkboxes to choose the possible size of the shirts.
there is one I only sell in S,M and L
another I sell in XS,S,M,L
so I think I need to use that WA relation tables.
The thing is, it is not an update table :-(
in the data assist insert record behavior, there is a section named session that allows you to store the inserted records ID to a session variable,
use this session variable in the manage relational table behavior to associate the sizes to the shirt id.
see this post by Andrew Reed for a good walk through on using the Manage relational Table behavior:
showpost.php?p=84393&postcount=17
Cologne
Hey Jason,
thanks for that great link! It works just fine :-)
But I get an red ! in my server behaviors list :-(
Is there something wrong?
Do you get it, too?
Cheers
Denis
a red exclamation mark only means that there _may or may not_ be an issue.
if the page is working, you can ignore it.
