Unique Database Value
Thread began 7/08/2011 8:36 am by Cologne | Last modified 9/19/2011 8:57 am by Jason Byrnes | 1916 views | 6 replies |
Cologne
that unique database value does not work, when I try it.
I get that error!
Parse error: syntax error, unexpected T_ENCAPSED_AND_WHITESPACE, expecting T_STRING or T_VARIABLE or T_NUM_STRING in /www/htdocs/w00d9940/email.php on line 13
line 13
$WAFV_Errors .= WAValidateUnique("LoveThisOne",$LoveThisOne,$database_LoveThisOne,"pcms2_users","UserID","int","0","UserEmail","text","".((isset($_POST["email"]))?$_POST["email"]:"")  ."?$_POST[\"email\"]:\"\")",true,2);
whats wrong here? when I look at the wizzards code its totally diffrent!
Cheers,
Denis
Cologne
ticket after ticket :-(
just let me know, does your extensions work with german DWCS5 the "de_DE".
I will try the update, thanks :-)
Denis
we do not test in foreign language versions of Dreamweaver
Cologne
Hey Jason,
maybe you can do in the furure. There will be a lot cutomers I think.
Cheers,
Denis
Base5 Designs
hi there getting the same issue am using 2.0.8 of data assist
Have you Updated your Security Assist version to version 2.0.3?
If you have a previous version of security assist installed, you will need to uninstall it before installing the newer version.
