DataAssist redirect issue
Thread began 7/07/2011 11:09 am by sandy170299 | Last modified 8/26/2011 11:30 am by Jason Byrnes | 1312 views | 7 replies |
sandy170299
When this page updates and redirects (members_Update.php?memberID=2), it should redirect to: $WA_redirectURL = "members_Detail.php?memberID=".((isset($_POST["WADAUpdateRecordID"]))?$_POST["WADAUpdateRecordID"]:"") ."";
This is what's specified in the code. However, it actually redirects to: members_Detail.php?memberID=2
Where is this path coming from? It's not even included in the code. Thanks!
there is a fix for this issue in the known issues section of the data assist download center page.
sandy170299
Pefect! Thank you, Jason.
you're welcome.
MikeyT
no redirect after insert
My form is inserting the filename to the database fine as well as the uploading the image to the designated folder. But I can't seem to get the redirect to work. I've applied the fix in the download center and cleared the browser cache, but it doesn't seem to have any effect on my situation. Not sure what else to do at this point.
OSX 10.6.8
DWCS5.5
DataAssist 2.0.8
can you provide some more details please.
you say the redirect does not work. Please be more specific.
Does it not redirect at all?
Does it redirect to the wrong page?
Saying something "does not work" is very broad.
we need to know what exactly _is_ happening versus what you are expecting to happen.
if it is not doing anything at all, I would suspect a PHP error is occurring, try adding the following code at line 1 to turn error reporting on:
error_reporting
(E_ALL);
MikeyT
Sorry, I didn't mean to sound so vague. It simply wasn't redirecting to the results.php page after file upload. Inserting the error reporting code at line 1 was the first thing I did, but no errors appeared.
For some reason its suddenly working today as expected. I can't explain it, but it is working now.
OK, glad to hear it is working.
