Trying to get digital file pro to download zip files.
I have been trying to get the digital file pro to download a zip file but it doesn't work. Can this program download a zip file, what about pdf, cbr or cbz?
yes, the download file behavior can download any file format.
send a copy of your page so I can see how you are setting the download file behavior up.
i need a copy of the PHP file that you applied the download behavior to.
compress that file into a zip archive and send the zip file.
2 problems:
1) you have not set the Folder where the file is located.
2) the File name should be a relative link to the file:
../20013Z.zip
it should just be the file name:
20013Z.zip
This is weird because I tried it again with the changes and it still does not work. Just to test it out I changed the file from a zip to a small .jpg file and it worked. It seems that something is going wrong when I try to download a zip file only, what would cause this?
Update: I also tried it with a pdf file and it didn't work. Only the jpg. Is there some size limitation or something going on here?
Please disregard the last post. It's working fine now. Thanks!
ok, glad to hear it is working.
