Root path not correct
When using the HTML editor to update a page there is a problem with the using the Creat Link
When I want to select a file on the server it does not show all files, only root/cms/
How and where must I correct this.
Thank you
Thank you
To set the root folder for the file manager, go to WebAssist -> Forms -> HTML Editor -> Site Settings, then set the upload directory to the root of your site.
