List results page and javascript error
I am creating a productslist page to be used in ecart5.
When I create a recordset and come to saving it I get an error.
"While executing findServerBehaviours in recordset.htm a javascript error occoured".
The created recordset does not show in the Bindings panel as I would expect.
I suspected the wincachefile at
C:\Documents and Settings\username\Application Data\Adobe\Dreamweaver 9\Configuration
which has been replaced.
Can anyone see where I am going wrong please?
John
The page code is:
<?php require_once('Connections/Conn_FB_PHP.php'); ?>
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
$theValue = ($theValue != "") ? "'" . doubleval($theValue) . "'" : "NULL";
break;
case "date":
break;
case "defined":
break;
return $theValue;
mysql_select_db($database_Conn_FB_PHP, $Conn_FB_PHP);
$query_rsProducts = "SELECT * FROM products WHERE ProductCategoryID = 15";
$rsProducts = mysql_query($query_rsProducts, $Conn_FB_PHP) or die(mysql_error());
$row_rsProducts = mysql_fetch_assoc($rsProducts);
$totalRows_rsProducts = mysql_num_rows($rsProducts);
?><!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
</head>
<body>
List Page
</body>
</html>
mysql_free_result($rsProducts);
