Error in IE 8 with SpryValidationConfirm.js used by form
Thread began 7/04/2011 7:24 pm by georgevargasa302189 | Last modified 7/06/2011 12:55 pm by Jason Byrnes | 1551 views | 5 replies |
georgevargasa302189
If I create a simple CSS form with Password and Confirm boxes works in other browsers but I get the error below IE 8. It also disables all the spry on the page.
If I comment out the SpryValidationConfirm spry, the page does not get the error and the other spry works correctly.
Is there a work arround for this?
I have attached the simple page with the form on it.
Webpage error details;
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; GTB7.0; .NET CLR 2.0.50727; .NET CLR 3.0.04506.648; .NET CLR 3.5.21022; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729; .NET4.0C; .NET4.0E)
Timestamp: Tue, 5 Jul 2011 03:20:52 UTC
Message: Object expected
Line: 69
Char: 1
Code: 0
URI: Form.php
Message: 'Spry.Widget.ValidationPassword' is null or not an object
Line: 193
Char: 2
Code: 0
URI: SpryValidationPassword.js
Form.zip
I am not able to reproduce the problem, do you have a link where i could see issue in a browser to troubleshoot the cause.
georgevargasa302189
I put it here;
Form.php
you have an olfdeer version of the SpryAssets/SpryValidationConfirm.js on your server:
// SpryValidationConfirm.js - version 0.3 - Spry Pre-Release 1.6.1
version 0.4 fixes this problem.
you can get an updated version of spry from the adobe site:
spry/
georgevargasa302189
Beautiful, thank you very much!!!!!
I deleted my spry assets folder, and let dreamweaver CS5 create it again after creating a page with spry samples on it.
Thank you again.
you're welcome.
