(Powerstore 4.5) Edited Region and now it's stuck...
Thread began 7/02/2011 1:37 am by CheopisIV | Last modified 7/23/2011 6:08 pm by CheopisIV | 2208 views | 15 replies |
CheopisIVBeta Tester
I tried to delete the 'Sample Product' from the page using the CMS, and now I can't edit the region. I thought I was deleting the info, but I think I deleted the actual editable section only as now I still have the 'Sample Product' and I can't do a thing about it.
I think I need to re-enter it into the SQL database, can someone point me in the right direction?
Here's my store link if you need to see what I mean;
store
to add the Most Popular pod back into the contnet management, run the following query:
INSERT INTO `ps4_contents` (`ContentID`,`ContentGroup`,`ContentRefID`,`ContentValue`,`ContentDate`,`ContentUserID`,`ContentPageName`,`ContentPageSetParentID`,`ContentPageSetOrder`,`ContentType`,`ContentParentGroup`)
VALUES
(15, 'Popular Pod', 'Header', 'Most Popular', '2010-01-14 13:44:04', 0, NULL, NULL, NULL, 'TXT', 'Home Page');
that test product will be replaced by an actual product when an order has been placed, you can put your store into test mode to place the order without going through the database and purchase the item you want to be the most popular.
Thanks, that got the pod back in. I went through in test mode and bought one, but it didn't update the pod. I got the email verification and the site told me I was in tesy mode... I'll buy another one and see if it get's updated.
Still not working, and a few oddities to report...
I've gone through and bought 5 of the same product and the 'Popular Pod' still is showing the sample product and not the one that's been bought. Now the other odd behaviours;
I had everything set up for the store, including my payment gateway of Paypal standard and my paypal address inserted. Even putting the store into Test mode, it continues to send me to the paypal payment/login screen. I had to also disable my payment gateway by setting it back to 'None' for the store to not send me through to Paypal in test mode. With this disables and the Test mode box checked, it would give me the message that I was in test mode, and I got confirmation of my order and it decreased my stock in the store as it's supposed to.
Any other suggestions?
Am I the only one having issues with the 'Most Popular' pod? The other issues are livable, but this just looks incomplete to show a 'Sample Product' on the live store.
Can I directly edit this region and just put my own info in there? If so, where is it in the files?
Thanks.
Just tried a complete reinstall on WAMP, but the 'Sample Product' box still won't update.
It was a complete wipe and complete reinstall with Powerstore 4.5 on a fresh MySQL database. All I did was create an item for $1 and a user to buy it with, then went through and bought the item 3 times. No change.
I listed a phone number and contact times in the support ticket, but have not heard from anyone at support, so will continue to post here.
I tried to call a little bit ago, but could get through, I will try again a bit later today.
Just got in and heard the message, I'm available for the next couple hours tonight or tomorrow evening. Thanks.
(jewelry dntatinl
It doesn't seem that this is going to be resolved quickly, so if I'm going to keep my license to this software (ie: not ask for a refund...) then a quick fix would be to edit the 'Most Popular' pod out of the home page.
If you can point me to the file and section that loads this area, and if I can edit it to being just an info box that I can control, then it'll work. If not, then I'm afraid Powerstore 4.5 isn't going to be my solution. Thanks.
