Setting the cursor to a form field on page load not working
Thread began 7/01/2011 4:08 pm by georgevargasa302189 | Last modified 7/02/2011 12:39 pm by georgevargasa302189 | 1944 views | 3 replies |
georgevargasa302189
I want to set the cursor when my page loads into the first item on my form. However there is a non editable onload statement in the template put there by CSS menu writer.
Is there a way to get around this.
I tried to put the following line at various places with no results.
<body onload="SecureSignin_Cool_Cool.Email_Address.focus()">
georgevargasa302189
I found I can get this to work by using an outside editor to change the onload statement in the non editable template area.
The question is, can this be done a better way so that if the template is updated, the edits to files with a modified onload statements do not have to be redone each time?
georgevargasa302189
I figured it out by looking at my template carefully.
It has the following statements in it.
<!-- TemplateEndEditable --><!-- TemplateParam name="Body_onLoad" type="text" value="" -->
and
<body onload="@@(Body_onLoad)@@">
In the file I can substitute the empty quotes after the word value with what I want.
For example,
<!-- InstanceEndEditable --><!-- InstanceParam name="Body_onLoad" type="text" value="document.Registration_Cool_cool.firstname.focus();" -->
Then in Dreamweaver I go to modify/template/update current page, and it substitutes the parameter into the onload statement in the non editable area.
The result is;
<body onload="document.Registration_Cool_cool.firstname.focus();">
Which works great and will be maintained if the template is reapplied.
georgevargasa302189
I now know I could have done this by selecting Modify/template properties/ in Dreamweaver and added the value there.
