I keeping getting an out of memory error on plugin
Thread began 7/01/2011 3:10 pm by kevin389160 | Last modified 7/05/2011 7:56 am by Jason Byrnes | 1296 views | 3 replies |
kevin389160
Hi, on one particular plugin I keep getting this error:
Fatal error: Allowed memory size of 67108864 bytes exhausted (tried to allocate 19639753 bytes) in /home3/culturai/public_html/webassist/framework/framework.php on line 214
What can I do to extend the memory so this can work or what else could I do to fix this problem?
add the following code at line 1 of the webassist/framework/framework.php file:
<?php ini_set('memory_limit''256M'); ?>
kevin389160
Thanks for the help.
you're welcome.
