header background image
powerstore/
How do I get the image to fill the entire hearder?
powerstore/
in the webassist/themes/sk_theme/css/default_styles.css file make the image the background for the header div:
#header {
background-image: url("/powerstore/imagesadmin/logos/bb_header.jpg");
height: 160px;
I tried what you said, nothing. :o(
I need the image to extend to the left border and the top border.
Thank you.
powerstore
i do not see the changed code when i view your site online, the change has not been uploaded to the server.
Still not working. I attached a screenshot of my remote files.
Thank you
if i look at this file online:
default_styles.css
i see the following code:
#header {
which should be changed to:
#header {
height: 160px;
per my previous suggestion.
The login / register button dissappeared dissappeared when I inserted the code
ok, try removing the height:
height: 160px;
I tried that. It came up under the header and above the nav bar
in default_styles.css change:
#header .links {
float: right;
margin-top: 38px;
padding: 7px 0;
#header .links {
float: right;
margin-left: 829px;
margin-top: 38px;
padding: 7px 0;
position: absolute;
top: 60px;
