Add To Cart Button error
Thread began 6/28/2011 2:43 pm by admin394099 | Last modified 6/28/2011 5:50 pm by Jason Byrnes | 672 views | 1 replies |
admin394099
Why is it that when I go to insert an Ecart Add To Cart Button, I am disallowed to select the option for Lookup Item ID from recordset.
It appears I am connectted to a database correctly, I went throught those steps succesfully, I can see the database I imported in my Databases Panel...
have you created a record set on the page?
the lookup item ID from record set option will only be available if a record set is defined on the page.
