dwt.php template not creatin correct file ref when updating linked pages
create plug in
added to template updated linked files
get fatal erro because the call at the top of page is
require_once( "webassist/framework/library.php" );
require_once( "../webassist/framework/framework.php" );
changed this to
require_once( "webassist/framework/framework.php" );
get same result if plugin added to editable, non-editable regions whether code outside html is protected or not.
any ideas
note if i add plugin directlyy into linked pages editible are all works fine, that is until you run template with plugin directives then the good directive is replaced with the bad one.
i need to get this working as it will save ne a lot of painful typing,
are these loca plugins for site or can these be called from anther website?
thanks a lot.
ps. started thi off some were but cant find it so i started new one .... sorry
