Problem with username
Thread began 6/27/2011 9:28 pm by kevin389160 | Last modified 6/28/2011 12:38 pm by kevin389160 | 950 views | 1 replies |
kevin389160
I'm needing to use a login (username) that looks like this 2011.1.1.09155 and it keeps returning an error message, (You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '.1.09155' at line 1). It seems to be reading just 2011.1 and says there's an error with the rest. Is there anything that I can do as this is the unique Id in the table?
Please Help!!!
kevin389160
I figured it out, so no need to respond.
