Captcha won't pass validation
Thread began 6/27/2011 6:54 pm by johna1964 | Last modified 6/28/2011 2:29 pm by Jason Byrnes | 2363 views | 7 replies |
johna1964
When I try to test the contact form via hosting service, I am unable to pass captcha validation, no matter what the letter and numbers, I cannot get through...
Please help, I read all I could find in the forums, I have no clues here.
The closest thing was needing to clear the session because captcha isn't validating, but I don't know where to do that....server behaviors? code? where?
The captcha text field is simply not reading or matching the text to the captcha image. I did add the refresh feature, if this has any resulting issues? If it did I am unable to view the WebAssit>Forms>Validation, but isn't it already validating through the Form Builders?
Can someone point me in the right direction?
Sincerely,
johna1964
first, test the servers session management, use the session test page from the following thread:
showpost.php?p=23826&postcount=2
if the session test passes, send a copy of your page in a zip archive so I can examine the code.
johna1964
sessionTest
Jason,
The server session management tested correctly.
Attached is copy of the page...
Thanks for you help!
johna1964
change the following code:
$WAFV_Errors .= WAValidateLE((strtolower(isset($_POST["Security_Code"])?$_POST["Security_Code"]:"")) . "",((isset($_SESSION["captcha_Security_Code"]))?strtolower($_SESSION["captcha_Security_Code"]):"") . "",true,4);
$WAFV_Errors .= WAValidateLE((strtolower(isset($_POST["Security_Code"])?$_POST["Security_Code"]:"")) . "",((isset($_SESSION["captcha_Security_Code_1"]))?strtolower($_SESSION["captcha_Security_Code_1"]):"") . "",true,4);
johna1964
Jason,
It's working now...Yeah!!
When I tested and viewed the email there is Lorem ipsum in the area of the email called Additional Notes. Is there a way to elliminate the Lorem ipsum?
Also;
Is this an a potential issue...
I had changed the file name from contactus_1.php to contactus.php. The code doesn't automatically update, does it...?
If this is the case, I need to find within the code contact1; for example:
$_SESSION['WAVT_contactus1_Errors'] = "";
and omit the _1 in all cases?
Thanks again!!
johna1964
no, you wot need to change the name of the session or anything else.
johna1964
Jason,
Thanks for all your work!
Johna
you're welcome.
