Form Presets
Thread began 6/27/2011 8:05 am by johna1964 | Last modified 6/28/2011 6:44 am by Jason Byrnes | 1584 views | 4 replies |
johna1964
Form Presets
After uninstalling and reinstalling; clearing the cache, restoring the original content presets, I continue having problems with a simple contact form. The validations are not hidden (show if...) and I am unable to style the css from the renentry points. If fact it won't style any colors at all.
When I unzipped the presets to reset the presets from my download folder, I recieved a message stating "Do you want to copy this folder without encryption" Is this normal?
When I tried to create the form again, I had the same issues.
Also, after uploading the webassist folder and the form to the server, the totals from the view cart button rollever stopped working. After deleting the webassist folder and contact.php, the rollever continues to not work...I need help with this also.(They worked prior to this form attempt; however, only in IE - is this normal?}
This last attempt the webassist folder is uploaded to the server...and I have no contact form, but the blank document is there. I don't know what else to do to make this work.
There are only three things I have left on my site and it all has to do with Web Assist extensions.
Please help...
Thanks,
johna1964
johna1964
Jason,
I'll let you know what happens...
Thanks!
Johna
johna1964
Problem is solved
Jason,
Thanks to you and tech support the problem is solved!
One most issue has to do with captcha. It is only showing a box with a question mark in it. I have the forms toolkit, and tried using that, but it didn't work...
Can this problem be easily solved?
johna1964
Most likely the GD Library is not enabled on the php server. If this is a local server, see the learning resources page for a tutorial on enabling the GD library:
resources.php?utm_campaign=Forum_header&utm_medium=Forums&utm_source=WebAssistForums
if it is a remote server, you will need to contact the host to have them enable the GD library for you.
