CMS PowerBuilder Log In Issues
Thread began 6/27/2011 9:06 am by info271221 | Last modified 7/20/2011 4:10 pm by Jason Byrnes | 2169 views | 8 replies |
info271221
The program including log in was working fine. I had a session with Ray and we made the editable region the same width as the customers site and created a couple new pages. That is all the changes that were made and now we can only log in as the super admin. The admin log ins do not work. I am attaching the files - in the zip file you will find Connect_BoneLakeCarpenters.docx That has the connections in it so that you can access the database, php my admin and users. I also created a failed log in page to be sure that the issue was failed log in and if you try to go directly to admin_cms/index.php you are directed immediately to the failed log in rather than log in page before you have even attempted to log in. Thank you in advance for your help.
Connect_BoneLakeCarpenters.zip
info271221
addtl zip files
Here are addtl zip files: WA_CMS and css
WA_CMS.zip
info271221
Addtl Files WA Globals and webassist
Addtl files WA Globals and webassist
info271221
Paths not correct
The WA Security paths are not correct. I can manually change them, but they default to:
/admin_cms/login_failed. when it should be login_failed.php Could this be causing other issues? I asked my host to check session.save_path in the php.ini file
designtrends210036
Power CMS Builder
I too have installed Power CMS Builder and I am having the same issue.
When I create a user from Power CMS Builder and tries to login, it refreshes to the login screen. Am I to understand that downloading those zip files will solve my problem too!?
in the WA_SecurityAssist/Helper_PHP.php file, chagne;
if (!isset($_SESSION)) {
session_start();
@session_start();
designtrends210036
PowerCMS Builder
Thanks Jason
you're welcome.
