SOLVED: File Manager User Files Problem
The user directory needs to be specified as /upload not upload. When I first implemented it, the browse button would not return a value (I select a directory, but the interface still showed no directory in the box), so I typed upload in. When I changed it to /upload everything is fine.
I don't know if the browse button failing is a common issue, but FYI I am using CS3.
The problem I am having is that if I enable folders, I am getting a view of all the web site folders starting at the document root.
My user file is set to "upload"
In kfm/configuration.php, I find that userfiles are set as follows:
$kfm_userfiles_address = '../..';
$kfm_userfiles_address = '../../upload';
What is going on there?
