Image folder
Where do I change the default value for the image folder that appears on the add images page , server upload tab.
I put in the wrong folder during power gallery setup
the default folder will always be the root of the admin_gallery folder, that step of the wizard is not to set the default folder, but instead to select the initial gallery images to import.
