user won't stay logged in
Thread began 6/23/2011 2:32 pm by Patbyrne322425963 | Last modified 6/23/2011 7:15 pm by Patbyrne322425963 | 730 views | 2 replies |
Patbyrne322425963
I created my Security Assist pages and decided to test out the userupdate.php page. I set it up to require the user to be logged in to access the page. I then went through the steps outlined in registration_on_checkout.php to redirect to the login page if there was no user logged in. That worked fine, but when I log in it tells me I am logged in, but still doesn't let me go to the userupdate.php page.
What am I doing wrong?
first this is to check the serves session management, use the session test page from the following thread for this:
showpost.php?p=23826&postcount=2
if it you are still having problems, add the following code for troubleshooting purposes to the login page just after the body tag:
<pre><?php var_dump($_SESSION); ?></pre>
after testing the login again, post back the session var dump results, a copy of the login page and the webassist/securityassist/helpergrouprules.php file.
Patbyrne322425963
I had another problem which required me to run the updated version of Security Assist and this fixed my problem, thank you.
