Sent emails -goes twice
When I press submit two emails are sent. One with an old format and one with a new format.
See attached the screen capture of the settings.
How do I delete the old format from being sent?
Thanks,
Larry
Thanks,
Larry
sounds like there are 2 instances of the Universal Email behavior applied to the page.
Open the Server Behaviors panel (Window -> Server Behaviors) if you see universal email in the list twice, remove one of them.
Found that there were 2 and deleted one.
Now a get an error message when I go into form edit and click finish.
Delete the Dreamweaver Cache file from the users configuration folder:
