Filter results using a dropdown list
Thread began 6/23/2011 5:22 am by david.cunningham54385851 | Last modified 6/23/2011 11:07 am by Jason Byrnes | 1089 views | 1 replies |
Hi all,
Can anyone suggest the best method for me to create a dropdown filter function on a datassist created results page. Basically I need to filter whether users are `withdrawn`, `active` or `both`, but need to retain the prior search query each time.
e.g.
1) Run a search for all users with the surname `jones`.
2) Results page brings back all jones's.
3) Use a list/menu to select only those jones's that are Withdrawn.
4) Use a list/menu to select only those jones's that are Active. etc...
Any ideas? Thank you in advance.
David
the search is stored in a session, if the search page does not trigger a new search on the results page, then the original search is used.
add your form with the select list to the results page, then add a second Data Assist Search behavior to add the search for the new parameter.
